2nd Test Begining..... 8 products to test.
I first want to thank our forum sponsor Chris Kelly "clkelly" from Amsoil, he donated the ACF, not even his product and the Amsoil Metal Protector. I think he is a fair and really honest guy. Just looking to get us the best product to use, his or someone Else's. The HD Metal Protector that most of us use as an undercoat I had, that's what I used on my Raptor based on the last test.
Materials
All the metal info is at the beginning of this thread. Nothing has changed, same metal but more of it.
What Kind Of Test?
On this test its going to be semi indoors. No sun or rain will hit it like last time. Its under a very protected over hang at my house. I live in Florida weather is like 70 to 85 right now. I will spray with a salt solution one time per day. From what I have read on the web "Eight tablespoons of salt (4 fluid ounces) added to one gallon of water (128 fluid ounces) will give you a good approximation of seawater." To size that down a bit 8oz and a teaspoon of salt. So that's what we will use.
Lets Start!!!!!
I sanded down all the steel, then decreased with gloves on, then sprayed each one by hand. Product in one hand and metal in another. I used a new set of gloves to prevent contamination with each product. I gave them a nice even coat. So they are untouched by human hands.
Take note I used the same steel for he Amsoil, Boeshield and Fluid Film, I had steel stamped them A, B and FF you guys can see that from the top view picture. I needed to make sure the test was pure. So those 3 guys got there old steel back.
Steel in last test was flat on the table, in this test it will be slightly at an angle.
This test is sort of a mix of things. I threw in some gun products to test. Allot of us on this forum are shooters and all the products say they prevent rust. I am of the opinion that no product is the triple threat as is claimed "Cleaner, Lube, and Rust Protection" I like a cleaner to clean, a lube to lube and a rust protector to delay rust. I happen to use the FP 10 as a lube only. It comes out good in the tests I have researched, so I wanted to see what it does as an anti rust product. The Eezox peaked my interest from things I have read.
So it's a under coat and rust test. Things should move quick with the salt spray. I will give it one week to cure. So starting next that will be the first spray.
![2nd Test 1.jpg 2nd Test 1.jpg](https://www.fordraptorforum.com/data/attachments/12/12866-2ec7389727404091c229fc9396f62344.jpg)
![2nd Test2.jpg 2nd Test2.jpg](https://www.fordraptorforum.com/data/attachments/12/12867-999d7b456dc69b3a7c3bc6dcf59227e3.jpg)
![Top View 3.jpg Top View 3.jpg](https://www.fordraptorforum.com/data/attachments/12/12868-14fd53c45d73fff46d0cd9ee18cb0455.jpg)
