Cheap transmission cooler mod.
B
BlueOvalF22
Willow Springs, CA
It's as tall as the radiator core and probably the same width as the stock T cooler and would snap into the stock T cooler mount if the ears were cut off the tanks.
Because of the size, it would just bash the condenser and pop loose if you did that.
The stock T cooler would have to be below the fan flow if relocated. So now I'm thinking shift the big cooler to the side and find a low buck off the shelf cooler for the PS that is the right size/shape to fill in the rest then fab up mounting.
B
BlueOvalF22
Willow Springs, CA
I've decided to drop the stock trans cooler below the 6.0 cooler. It will still be a huge improvement over the stock PS cooler that is part of the condenser and blocked off from airflow by the radiator support.
BenBB
Lots of different places
Right? And would still about double the P/S capacity even without the puny stock one. Behind bumper would work great as long as you don’t have a winch there or something.
B
BlueOvalF22
Willow Springs, CA
I also found a better option for the plug in the pan. A pan with a plug.
$35.99
Motorcraft filter for $23 and a bunch of Motorcraft LV.
So when I go to take my old pan off I'm just going to drill a small hole where this one has a plug to make it less messy.
