Changing gear clunk sound ( sometime) , new raptor normal?
Badgertits
Ma
What does taking the negative terminal off do?
Resets what?
Thanks
It clears the learning algorithm from the TCM. It’ll “relearn” your Driving behavior. Sometimes after having already broken the truck in it helps to have this done again- particularly if you happened to have a TCM reflash from dealer too w/ whatever updates you may or may not need.
florida
I’ve definitely noticed it clunks between shifts if you happen to be lifting throttle as it’s shifting/skipping gears. Sport mode is so rough I mostly don’t use it.
Did you ever figure out the clunking ? I have a 2012 and first to second gear when I let of the throttle it clunks .. I’m not sure if it’s the transmission or transfer case making the clunk
isis
PA
No but I don’t think you and I have similar transmissions or transfer cases. Mines a 2017. Mine is pretty minor and mostly just in or out of 3rd gear.
