GEN 2 Catch can after almost 2k
thatJeepguy
GA
Love to hear more on that to understand that better. Under boost blow-by would happen more so where does the manifold come into play?
The manifold cant simultaniously pull a vacuum to pull on crank case vent when its positively pressurized.
Badgertits
Ma
Hey guys I installed this around 2000 miles ago and wanted to see what it would collect here’s my results I’m pretty happy considering seeing other guys cans filled with something other then just a small amount of oil let me know what you guys think.
Hey just an FYI/update on this JLT catch can & changing it- I just got 1-2oz out of it (I empty the catch can every oil change) & one thing I noticed was there was oil residue around the canister & the fittings- the canister had actually backed off a couple threads, wasn’t entirely sealed- it did same thing last oil change…but I also didn’t hand tighten nearly as tight as I had on previous changes b/c it was a PITA to get off…well….i didn’t throw any codes & was still doing its job but from now on I’m gonna make sure it’s plenty tight when screwed back on & id recommend you do the same lol
zacharyguyjordan
Bennett Co
Bro I noticed that too I had to use some channys to get it off I couldn’t unscrew it with my hand but I assumed it was like heat soak and it would eventually tighten up again and I would fight it next time but good advise I’ll check it
donk_316
Southern BC
Why doesnt anyone use RX catch cans anymore? their system would vent under vaccum or boost. They were all the rage when the early ecoboost came out.
