I have confirmed the correct Molex connectors to make the Zen-A2B completely plug and play eliminating any soldering/splicing into the factory harness.
The can-bus plug is also the Speaker output plug. Both speaker channels and can-bus run through this plug so you can use the same plug at the same time! The only thing you would have to add is tweeter channels if you were running active crossovers. (Let me know and I can give you part number for the pins) If running passive crossovers in the door, no modification or extra pins necessary! It will work plug and play.
Power and Ground Connector
https://www.digikey.com/product-det...UanVXaHdMdFVBcDF1V1B2Z1dJbnFXWUpoNFVYUEUrIn0=
Can-Bus/Speaker output Connector
https://www.digikey.com/product-detail/en/molex-llc/0346900201/WM14539-ND/2297947
So my plugs, just came in. The Speaker Output connector fits, but the Power plug does not.
Can you post a pic please of the new plug and the factory harness? That is odd.
I think the tab is the problem.
