Can't balance my method nv's
BIRDMAN
Birdministrator
Boston
Is it digital ? and is digital better ? Wheels will be going on by the end of the month. Waiting for Vince caps .
Brown Line Metalworks was the vendor. I have their digital torque wrench. It's pretty good, gets a little sketchy up around 150lb-ft but plenty of leverage.
infinitereality
SLC IR/8
Louisiana
Just to add, I had my tires rotated. The front shook a little before due to cupping of the tires, now since I've had them rotated the front bounces pretty hard between 70-75 so I know it's the torquing of the lugs is the reason.
I need to find some hub rings to help align them easier.
twlhunter65
Well-Known Member
Massachusetts
So I went to HFT and baught thr torque wrench, jacks, and a bottle jack for less than 80.00 bucks. Problem is the jack and stands wont get the truck off the ground high enough! So do I use blocks of wood ? I'm not spending 200.00 0n a floor jack, just found jacks that are higher. I may just use the stock jack to set the stands ?
AZEngineer
Phoenix AZ Area
I've been down this ****** road before. Why F with generic wheels?
My learning; I will never again use wheels that are not hub centric for my truck. Period. If they weren't manufactured that way and I'm desperate for different wheels I will have the new wheels machined to accept aluminum hub centric rings.
Look how much time and likely money you've wasted on this. If you still like the wheels find a shop that will install aluminum hub rings. As long as the wheel is not bent this is almost certain to solve you problems.
Huck
Chicago Sw Burbs
I have no problems with my method nvs and 35" toyo mts. I don't recommend wood on top of a jack, there's not many flat spots on the frame
infinitereality
SLC IR/8
Louisiana
Any suggestions on hub rings? I'm running MB TKO wheels, but like options. I know running wheels I had on old GTO hub rings did save alot of wheel alignment headache!
