waveslayer
Looks really really good. I want bumpstops upfront!
My wife thinks I only have 3 guns
I really wish that they would have come out with their own spindle instead of using the stocker.
The stock ones like to crack or bend. might not be a terrible idea to grab a set of gen1 spindles, have them gusseted and install them with the kit. Or maybe opt for the ADD spindles.
I've changed 3 out on gen2s that were bent so far.jerry is very adamant that it’s not needed on Instagram. But I’m with you, plus they could have changed the vertical uniballs to horizontals like the svc kit at the same time.
7k seems a lil pricy for uppers/lowers and axles/tie rods. The bump system is an add on from my understanding. In the end your gonna be 15k with shocks easy.
Just curious, from impact or just good old Baja beat down?I've changed 3 out on gen2s that were bent so far.
Talked to Camburg today. they are shooting for January 1st or thereabouts for the initial release. If you order by then you’ll get the reduced intro price. It will be more pricey after that.
They tested using 37” tires. Even though the arms push the wheel forward 1”, the tires clear the headlights OK. They said they didn’t have to trim the rear wheel well/pinch weld area.
https://www.facebook.com/CamburgRacing/photos/a.10150661665687248/10157653954632248?type=3&sfns=mo
if you scroll down to their Nov 5th post, you’ll see some pics of their install and you can see the intact pinch weld area
