Cam Phaser/Engine Failure Reports
Status
Not open for further replies.
Johnkn
LaPlata, MD
waveslayer, I might suggesting timing it on the next cold start and see when it stops. Then on your next complete cold start after that, from inside the truck check your oil pressure. On my 2019, my cold oil pressure high at ~60psi and instantly drops to ~30 in about that same time. Perhaps is just additional noise due to the oil pump at cold start. Good luck..
Ruri
SoCal
I had my cam phasers fixed twice and both times the dealer said it was a new part number for the cams. Now they are rattling for a third time.
Jeff-Ohio
Cincinnati
Guys, does this sound like my cam phasers are going out? http://cloud.tapatalk.com/s/5dd610ae55abc/20191120_185126.mp4
My wife thinks I only have 3 guns
We have the exact same issue. Listen to my video below. My truck is actually at the dealer now for the seat recall and I asked them about the noise you are pointing out. They called me yesterday to tell me that they need the truck for another day (today) to try and diagnose the problem. The tech can hear what I am talking about, but hasn't been able to figure out what is causing it. As with you, my noise is definitely the loudest from the driver's side wheel well.
waveslayer
CA
To clarify the noise will completely stop right at 54-56 Seconds. I have tested it 3 times now. I just wanted to see if I should be concerned or not... that's why I asked.
Johnkn
LaPlata, MD
Does it stop at the exact time your oil pressure normalizes at idle?
Jeff-Ohio
Cincinnati
Okay ..... I just heard back from the dealership regarding the noise on my 2019 built on April 12th and they said my VCT (variable camshaft timing) is going bad and it will have to be replaced. The part is reportedly on back order until January or February, but I was assured that I am not in danger of doing any damage until it is replaced.
mezger
interesting. unless the sound goes with engine speed, that sounds a lot like wastegate rattle (waste gate actuators are visible). mine will make a rattle like that especially on cold start, often gets quiet after (i'm guessing) it's done lighting off the cats.
edit:
@waveslayer, your is the exact sound i'm talking about and mine goes away just like that. might not be waste gates, but when the truck is cold and off, grab the wastegate actuators and rattle them... makes the same noise.
here's an example:
somehow i've always considered it to be related to cat light off, but i'm not sure how wastegates would be utilized in lighting off the cats.
i know my M3 cold start sequence sounds badass as **** instead of rattly.
in addition to the classic cold idle phaser noise (only lasts 3s or 5s or so... just long enough for the oil pressure to come up), and the wastegate rattle, my truck now has a distinctly different warm idle diesel-like rattling sound that i suspect is related to tensioners/chain/phasers, and it very distinctly comes from the front of the engine. it has a very different sound profile. will be taking it to the dealer very soon. could be DI, but i'm thinking not.
for another datapoint on start/stop, my truck is driven in sport mode 100% of the time. it also has its oil changed with mobil1 full synthetic every 5k miles, i check the dipstick every 1kmiles or so, never ran it low.
Tr4ckD4ys
Midwest
Guys - please help out here. I’m hearing very similar rattle issues (not as intense as some folks immediately upon start up). I think my case is particularly frustrating. The vehicle is 3 days old and has less than 300 miles. Can you believe it? Listen to the video below and tell me what you think this is...
Status
