Cam Phaser/Engine Failure Reports
Status
Not open for further replies.
jgree32
Curious as well. I just ordered the cobb tune. Cam phasers are completely different problem than what a tune would do. @RMB_Ryan has put quite a bit in here about it about what the problem is. Ford has identified the issue that they have updated the design on it with the "CC" end code.
Any links to the information you are mentioning?
signalbobby
That noise you hear that is ticking at cold start is likely the lifters not the cams directly. Can be common but not good, however if you hear it from one bank to another their is something worth opening it up and having a look to find what it is.
The oem filters as well as most quality non oem oil filters like Amsoil, etc, use an anti drain-back and identical bypass spring pressure to be able to meet the oem spec. It is the cheap version of certain oil filter brands that will be the issue 99.9% of the time.
The cam phaser issue is a multi part problem.
1- new phasers have just been updated and released and they I believe are now engineering mark CC at the end. First was CA and then CB, now ends in CC. Apparently they did something to a sticking locking pin and springs. (Ford maybe even updated blinker fluid to help who knows.) [emoji849]
It is our experience that we can help the issues with cam timing issues such as phasers, I take cams rolling aft to positive degrees and with a few other things.
1- a cam grind focusing more on changing duration, and adding a little lift will help a lot due to how these cams are often in an “at rest” position. With zero load on any lobe causing the cam which is at rest at the moment to be lose and actually move it by fingers back and forth These Gen2’s this is heavily pronounced over gen1.
With a DOHC 60 deg v6 cam timing, chain, phaser issues and erratic cam events are very common across all platforms. Because each cam has a neutral or no load position during each of its one revolutions, (x4 cams) it has been known to cause erratic timing events which can and will increase wear on parts such as phasers , possible broken tensioners and guides.
This is something that had been an issue on platforms since variable cam timing was introduced in a 60 degree v block v6 With DOHC. If you added say two cylinders and had a V8 the extra 2 lobes per cam, per bank, would lesson the amount any cam is at rest because your keeping load on the cam from adding another set of lobes that will be loading a lifter and limiting the at rest position by a good amount to make a difference.
One solution would be to delete VCT? In my opinion, in a truck, you lose everything that makes these what they are and a ton if not all the HP TQ in the low end is then lost. That would suck, not fun and the ecoboost kicks a$$ because of the fun from the amount of insta-torque and low end power it can generate. You’d have to keep it wound tight at higher rpm to feel the same and raise rev limiter IMO to 8500rpm.
In lieu of deleting, I’d prefer to limit VCT movement. I would do this with the addition of a simple regrind of the oem cams and add like 20 deg duration on exhaust cams and 5-10 on intake cams roughly. Not only will you have something to make more power now, but you are helping the issues with the erratic timing and killing two birds with one stone. Plus the wife would understand easier that your fixing the issue, not buying cams.
[emoji2936][emoji3061]. Yeah, my wife, she knows my playbook by now. lol
With the cams ground, my suggestion would be to pin or limit the 4 cam phasers accordingly based on the amount you changed duration. So basically if you add 20 degrees you pin or limit 15-20 degrees of the cam movement.
Generally we will limit cam phasers by the amount of duration we add and when we start really adding lift and or real duration we have to limit VCT usually deleting it. Too much stress on phasers is bad.
With the ecoboost (gen1 and Gen2) the intake cams have a whopping 60 degrees of variable cam movement already. We for sure consider that as much as we would like to see and 60 degrees of movement is probably already causing added wear on the phasers which is seen by the mileage many are having issues at. Now throw into the mix their is an added erratic cam that’s yanked from being smacked every one of its revolutions for a millisecond and timing events are thrown off and from the rather long and frequent amount of time the cams have no load on them. This is and will exacerbate and increase wear on phasers and all parts.
Particularly with the worlds absolute worst timing chain tensioners that have almost zero consistency and I think ford is whacked for even using them or thinking of it. Use the GT500 style tensioners and be done! Wish they fit
By grinding the cams and changing the duration, you are now changing how large and where base circle and center lines are. This can greatly change how often and how long each cam is not loaded and therefore limit the window for erratic behavior by cutting down how often these cams have no load on them and literally are lose in that position and this all cuts that amount down by a fair margin. Tons of issues which cause V6 DOHC’s problems with timing, and I could show you if you and you’d hear the popping noise when we see a cam get to its neutral position. and you can hear when each cams at rest if you were next to me in the shop and they make little popping noises when the lifter on a bank sees no preload on them. By limiting the movement of the cam phasers you are putting less stress on them, and by helping limit
(as much as possible) the amount that these irregular and wearing events happen will prolong life of the timing chain drive assembly.
By limiting 10-20 of the degrees of movement will go a long way with adding to the longevity and preventable accelerated wear on the parts within the components. Gen1 cams due to valve train type and lobe design are naturally at rest less often than Gen2 roller rocker style lobes and lifters.
Next issue, the tensioners. More on this later, but tensioners must be upgraded from the crap that’s in these now. We will be working on a full timing kit with all parts that are not only stronger and last longer, but allow options as to what you do with VCT or how much it is able to move.
Quick look inside phasers. These are the smallest phasers two major manufacturers we have been working with for 2-3 years on the Gen2’s and they both first said they were shocked at the small size off these phasers and probably the smallest phaser they had ever seen across any platform.
Theres another right after this. Go back a page or several depending on what your view setting is.
rtmozingo
North Texas
? It's enough that Ford had to make an update on a part they cant get right.
Unless it isn't the part itself that is the problem, which evidence very much suggests is the case. And if I recall correctly, Ford subcontracts the cam phasers and chains....
signalbobby
Under Visteon which is Ford.
WraptorBoy
US
Hi All,
Prospective Raptor purchaser here... I read all 36 pages of this thread and other threads. Whew!
I have seen one post, very unspecific, on a 2019 having this issue. But since that poster wasn't sure it was the "cam phaser issue" sound, I'm not sure this problem persists in 2019 models. And another post was generalized that it's happening on 2019s.
I realize this issue affects a small percentage of the larger percent of sales, but this is irrelevant. If the phasers fail on an engine, and all engines use the same phasers, then they must fail on all engines... UNLESS... those particular phasers were simply a defective casting then only those will fail... which seems to be the case. Of course we won't know unless a poll is taken on every 3.5l ecoboost ever sold, but I digress.
If 2019 owners (or anyone who has the data) could be so kind, please answer the next question with some empirical data such as:
Does anyone have a 2019 with this issue?
year:
mileage:
build date:
if you 'hear' the issue:
diagnosed by dealer?:
got it fixed:
I know its a little bit of a pain, but thanks a bunch in advance!
Prim
Midland
Went and test drove a 2017 with 31k miles that I'm interested in buying at a local ford dealership. Salesman noticed the CEL on the dash. Took it to their shop. Came back with cam phaser issue. He called me a couple of days later saying Ford warranty told them to swap entire engine. Question is should I buy it?
Sent from my SM-N950U using Tapatalk
theandrewpham
Hey everyone, I thought I would share my experiences as well.
2017 Raptor : build was Feb 2017
First oil change at 3k and used Amsoil + Filter
Im at 30k now. Lightly driven and hard occasionally because she's my road queen and IDGAF what other's say. The only dirt she sees is during hunting season.
I have a tiny rattle upon start up. At first, was told it was waste gates cycling. Drove 2 years with it. Did not affect performance. Never had an issue with my truck. Never got worse.
I took my raptor in two days ago to check that rattle again. They returned and said there was no issue. All I can do now is watch and see what happens and if it gets worse. The thing I really wanted to share was that I was told that OEM filter and blended synthetic oil was key for these engines. The oil ford uses with their filters have been tested with these trucks. He also told me that Ford specifically says no amsoil. Reason being is because of different oils produce different pressures. Some not enough, some too much. There has to be the right amount of pressure for the oil guides to work properly. I asked them to do an oil change and use the blended synthetic they recommend and a regular ford oil filter. (He said ford performance is not needed). I will see if the oil change will reduce or worsen my noise. And to repeat what other's have said, it's better to use ford oem parts so down the line when you have a warranty issue, there's no reason for them to turn you down. They might just want to make extra money to tell me all this and scare me away from amsoil, but I am also a believer in using OEM and engineered specific products. Saves me money too. I'll update what I hear tomorrow.
SL75
Toledo
Hi All,
year:
mileage:
build date:
got it fixed:
2019 has same part number, and has had a failure rate since 2017. Ford doesn't have a new part number available that works yet. Ryan here is working on a fix since he identified the root cause as a Ford design problem.
Status
