Broke Locking Diff Pin in Rear Axle
dkfc13
dkfc13
HPA Systems LLC.
SE Michigan
Here is the last few pictures sent to me by the service dealer.
formuladriver01
Andersen AFB, Guam
Same thing happened to my 2002 f150. I went will all aftermarket parts and it was about 2500 including a eaton auto locker. That was gears, diff, master rebuild kit, and install. At the time(about 4years ago) eaton did not make a E locker diff for the 9.75 rear end.
wiz1500
I had a conversation in regards to your problem at dinner..
I will have pricing for you tomorrow for a complete assembly.. You will probable have 2 options replace what is broken. You could go with stock "10" parts or upgrade into "14" axle shafts..(bigger)....
I'll P.M. you tomorrow with my phone # and we can talk about it..
Is your pin in 2 pieces or 3 ?
dkfc13
dkfc13
HPA Systems LLC.
SE Michigan
Thanks Wiz. I only see two pieces in the pictures but I believe there are 3 pieces. I spoke with the selling dealer and they said that this failure mode is caused by turning the vehicle sharply when the diff is locked.
TheJoker
N. E. Massachusetts
That was what I suspected, and why I asked if the diff was locked when the failure happened. Could it be that the diff was locked and you simply didn't know?
dkfc13
dkfc13
HPA Systems LLC.
SE Michigan
What I can tell you was the diff lock lever was in (not engaged) and the diff lock light was not on. I was also not in off-road mode as I was getting on the highway.
I did ask the dealer if they thought that the diff lock might have engaged on it own. I was told that they had no idea.
I have not yet locked the diff since I purchased the truck two days prior to the rear axle breaking.
Boss Hoss
Colleyville, Texas
Wiz--you are good troops for helping out the OP. Just make sure he does it right. Lot of metal was getting ground up from what I could see! Bummer---one reason I don't buy used vehicles. Never know what the previous guy or gal did to the vehicle or did NOT do to the vehicle..
