teamster
An update on this: truck is still at the dealership. Definitely was not the wheel speed sensor. Reportedly, "several modules are offline, not communicating, but not flagging faults either. Possible either share grounds or share power. Need to test wiring and inspect electrical schematics for offline modules."So, looks like I'm having a similar host of issues. I'll put my writeup here instead of opening a new thread to keep continuity of conversation and ease future drivers googling their issues.
I was taking my '17 screw through a pretty mild but tight technical trail with a few rocks and drops. After getting through a feature, my power steering went completely haywire - angle sensor was swinging hard from 45 degrees left to 45 degrees right, back and forth, all while my steering was centered unmoving. A faint whining was audible when trying to manipulate steering. From here, the dash threw every error you can think of: AdvanceTrac, Adaptive Cruise Control, ABS, Hill Descent Assist, etc. I was able to wrestle the truck back to camp and pull codes using FORscan.
The most serious code thrown was C1B00, an error in the ABS sensors. The DTC indicated that the sensor was sending erratic data, and the truck went into limp mode as a result. While a physical inspection of the cables and sensors didn't show any damage, it's possible that I came down on one while crawling. I had the truck hauled on a flatbed to my dealership, where it is waiting to be diagnosed now. I'll follow up here when I have more information or a solution.
In the meantime, this is a great reminder to make up for Ford's shortcomings in design, and get some deflectors for your ABS and vacuum hoses. Even if that's not what happened to me here, there's always a chance it'll be the culprit someday in the future.
When asked for more info, the tech didn't have any. Just that there are modules offline and they can't seem to get them back online. I was wondering if it was related to the wheeling I was doing, but the tech believes it's just bad luck and shit timing. They're working on trying to get the modules back online, but it could be anything from a bad ground, bad power, broken wires, bad modules, or something else entirely.
So, uh, guess I'm truckless for a good while longer. Wish me luck.
