BOV not making any noise
nikhsub1
Los Angeles
I removed the re-circulation tube on my factory BPV and I can hear it with the windows up. Maybe y'all should go back to factory?
That's what I've done for now. I called turbosmart and they recommended i disassemble and clean the entire unit which i did - vid here:
Reinstalled and still it doesn't open. Maybe my actuator? Anyway, I've put the OEM back on for now and it works fine, it's just super large etc. Waiting to hear back from turbosmart.
smgilles
You would think they’d tell us there is some kind of maintenance schedule to prevent early failure of these things?
nikhsub1
Los Angeles
Well to be honest, it's essentially just a piston in a housing. Mine wasn't that dirty. I think mine might have a bad actuator. I can move the piston with my fingers so it does move easily.
smgilles
Mine wasn’t dirty either but I could not get the piston to budge.
downforce137
In Diana
as i said in countless turbosmart EM BOV posts, its junk..
when it works, its pretty loud, even with windows up, on SVC intercooler...
but, it was always messed up, stuck open, stuck closed, check engine lights... i bet i took it off once every 30 days to service it..
i switched to a mechanical Turbosmart supersonic, and have not had one single issue since then, on the same SVC intercooler..
get rid of that junk
Wfo
Syracuse
I put the turbo smart bov valve on late last fall. It has now stopped working! I’m currently running a tow tune and plan to go back to my custom stage 2 goose tune to increase the pressure, I have also sprayed the heck out of it with wd40 and Kroil.
nikhsub1
Los Angeles
I had the same issue. Most likely the actuator. I sent mine in when it started doing what yours is doing (not working) and they fixed it free of charge. Been running fine ever since. If the piston isn't stuck and you can move it with your finger, most likely the actuator.
