How To Blend Door Actuator Replacement with Part Numbers
matrix243
Calgary, Alberta
A circuit short DTC can be a faulty control module, damaged circuit, or faulty actuator.Since you’ve already replaced the actuator, you’re down to the module or circuit. Do you have a basic volt meter? Checking the circuit is not very difficult.
Thanks for the help, much appreciated.
Sozzy12
Montana
Well hell. My passenger side ac quite blowing cold. Picked up a new actuator at the dealership.... Just another project.
matrix243
Calgary, Alberta
Making it so hard to hold onto this vehicle. I once again have lost another actuator (temp blend) and wasn't able to repair previous (mode blend). This time driverside temp control is down on the coldest day of the year, and I've previously replaced passenger side temp control. So I'll be ripping out the console, bending the duct work and breaking the actuator tab as per makuloco shortcut fix here, as opposed to removing dash and draining coolant and purging coolant system. Good times.
matrix243
Calgary, Alberta
If I had this repair each individual time at the dealer it would now have accumulated about $7500.
Is there maybe an option to go back to the old heater cable design?
