Black Splined Lug Nuts
vince7870
long island NY
Hoping to have a complete new set made by friends machine shop using the stockers to get measurements.
I told him he might get swamped with calls if he pulls it off.
I'll definitely be posting pics.
I though of using stockers cutting with a pipe cutter and spot welding a flat piece but since I'm not a welder I've decided to encoporate a machinist into my plight!
I wouldn't go anything less than 14mm x 2.0 the reason for that size is that it utilizes maximum threads on the studs which is safest, plus if you got shorter ones they won't tighten down far enough on the stud to secure the wheel, onlything I can think of for your desired application is maybe an open ended lug to allow the stud to pass through the lug just enough to get that flush look. Are you planning on modifying the nv center caps or make different ones completely?
