Best lift/level options- collars & deavers?
Raptor Jim
Firestone Colorado
I have been running 2.25" collars on my SCrew and have no complaints with it. Seemed to level it out perfectly and as far as ride quality went, I am not sure i noticed a difference. I also went to 37" K02's at the time as well, so I suppose that could be why. But was very happy with them, would buy again. Really helped me from hitting the skid plate while off-roading
What wheel and offset are you running with the 37's?
Nick@Apollo-Optics
I'd go with Eibach from springs and Icon rear leaf springs. The Eibach springs in the front will net you 1.73" of lift on your 2019 and the Icon rear leaf pack will net you 1" in the rear.
Additionally, if you really want more lift out of the front, you can go with the RPG 2.25" collars. They're less than $40 more than the Eibach springs and will get you the height you're after.
Let me know if we can help answer any more questions for you. We've got the parts in stock and ready to ship if you're ready.
Mbdurham
Georgia
What are the advantages of going Eibachs instead of collars??
Not sure about the collars but I really like the ride with mine and the Eibach especially in corners feels much more planted. I also went with 37’s a week later with -6 offset wheels and did have to trim the inner fender slightly. I just trimmed following the contour of the body and no issues. And as I mentioned it lifted it perfectly level and I love how it sits now. I feel better doing a full spring designed for that instead of a collar that puts different tension on the stock spring. No science behind it that’s just me. Also not sure about all collars but I don’t think they have a mounting point for the live cable?
LeboRaptor
Nyc
Did you have to do anything else to fit the 37” tires?
Gakoman
West Lafayette, IN
Nope, no trimming or anything else. Just the 2.25” RPG collar in the front, but keep in mind K02’s are not true to size, they’re a bit smaller, so I don’t know about true to size 37’s
sixshooter_45
Arnold
Yeah, approximately 5/8" on the Diameter or 5/16" on the radius for the 315/70 R17 BFG KO2'S. Not a whole lot of difference but there is a little and not sure about the 37".
Badgertits
Ma
One is an actual spring w/ R&D behind it that is slightly stiffer & raises front end w/o compressing shock, the other is an adjustable snap collar that is essentially a zero R&D cnc’d Piece of AL that while may not significantly alter the angles of your A-arms ruining ball joints/bearings/bushings over time, but I don’t see how they wouldn’t compromise overall shock travel, cause the truck to ride rougher, OR in the very least be an automatic “warranty voider” should you have a front suspension component issue.
Plus they’re expensive for what they are. Not as chintzy as a block style leveling kit like “rough country” which is just redneck trash, but not worth the $$$ It’s kinda like deciding between bilstein 5100 adjustable shocks vs. a block kit for leveling the suspension on a “regular” 1/2 ton.
Personally going w/ geyser springs & +3 deavers lift a couple inches & leave an inch of rake plus some room for squatting under load w/o riding nose high.
sixshooter_45
Arnold
Do you know if this setup would allow you to run 37" tires without any rubbing even with full articulation?
