Turf,
That's great. Did you show him the picture above? Also, whatever they come up with should work with Line-X'ed and non-sprayed beds. How thick do you think the Line-X is?
Yeah, I'm thinking something as simple as a bar that extends across between where you drilled the holes for your bed bolts, with a tension adjustment nut or two. A Quick disconnect would be nice too.
Let me see if I can explain what I picture in my head. Bolt on "cups" on either side of the bed. the bar has square brackets on either end that drop in to the cups, insert receiver hitch like pin (but much smaller) through cup sides in to brackets, cotter pin in to beefier pin. Tensioner nut in the middle, reverse threaded on one side so that when you turn it with a large wrench it pulls the bed sides in, or in the case of an un-widened bed, protects from widening (hopefully).
