Bed Bolt D-Ring Tie Down Points AT COST
Status
Not open for further replies.
Jkysh
Last I checked these were on hold for a bit. Sent a PM a few months back, would still love a set when op gets back in the shop
mp_tx
Austin, TX
Add me to “want a set when available” list.
Just a heads up to those that have yet to order, yet to receive or yet to install.
Note the torque rating on the first page in @Talbor’s instructions - 56 foot pounds. That’s about 1.25-1.5 x ar15 barrel torque. You can do it with hand ratchets.
I made it through bolt 1 and partially stripped the 2nd one trying to loosen it. I think it can be removed with good tools, but these bolts are in there at 4-5 times that 56 foot pounds on my Rap. That should’ve been a clue to stop but wasn’t for me. I had to resort to a 2 foot breaker bar on the first bolt - again, this should’ve been a clue to me...
When I revisit this, I’d love to know what those of you with spray in bed liner are doing to clean up the bolt heads. it’s a bitch with a pocket knife and I’m still trying to think what I can use to get the bolt head clean for the torx bit ( t50 PLUS in case anyone’s wondering ). I’ll bet I fought for 20 minutes per bolt just to get the head clear enough for the torx to seat.
If you get the kind of resistance I’m seeing, don’t force it or try to force it if you don’t have the tools to get the bolts out.
MEATSWORD
Arizona
You could try a torch on the bit and melt the liner inside of the bolt.
May have to step up to the final size though
ZackZ
Michigan
Bolt heads strip very easily. Hand tools are your best friend. Lock tight on the bolts from the factory doesnt help
Palerider
I've received the d-rings but have have to tackle the installation. Sounds like it's going to be an absolute blast because I have a bedliner. Speaking of which, those who have liners and have completed the install, what did you do as far as bed lining the d-rings goes? Just some touch-up?
Sent from my SM-G950U using Tapatalk
Status
96,553
60,525
solozero
