Baja Designs - NEW Laser Lighting! Ultimate Long Range Lighting
Slow6
AK
Interested in checking out Baja Designs Laser Lighting? Want to know how they compare to our LED offerings?
We are doing at night demonstration at Overland Expo West. Our booth will be set up during the day with our product line. Stop on by and check out the latest and greatest from BD!
Booth P10
Overland Expo West | 5/17-5/19
https://www.overlandexpo.com/west
(XL Laser)
(Hybrid LED/Laser OnX6)
What’s the down range distance on the pictures? Is that the only light source in the photo? The faint light on the ground in front of the XL, is that just wash or different light source?
Baja Designs
Baja Designs
I don't have exact distance measurements for these shots, sorry.
These are with lights on only. The light you are seeing outside of the center intensity is the spill light. You aren't stuck with a focused hot spot and complete darkness around it :)
Slow6
AK
Thanks.
Joey
Wyoming/Colorado
Can you take a 10" or possible 20" OnX6, Hybrid LED and Laser Light Bar and install it in top center of the grill cutting out the grill itself so the lightbar is not blocked in any way on a 19 Raptor
Baja Designs
Baja Designs
We haven't seen this type of install done before. It would require a custom mount to mount the OnX6 in that location. It's certainly possible someone can make something work
Baja Designs
www.bajadesigns.com
for all that heartache, wouldn’t the Caliber 9 grille be a better solution?
The S8 kit is tight against the shutters and the Onx6 will be tighter for sure and mounting would have to be fabricated.
yeah, it’s more expensive, but will be a cleaner implementation as well as plug and play.
Baja Designs
Baja Designs
A Caliber9 Grille Kit would definitely be a solution to getting the OnX6 in the grille location
https://www.bajadesigns.com/products/Ford-Raptor-17-19-Caliber-9-Grille-Mount-Kit-20-OnX6.asp
We don't sell it with the hybrid or laser light but definitely can!
I think the C9 would be high enough for long distance lighting.
