Baja Designs: General Discussion Thread - GEN 2
1badjk
Mississippi
MDJAK
NY
First and foremost, a huge shoutout to Nick @ Apollo Optics and Baja Design support.
Before I had heard of Nick, I ordered a set of lights directly from Baja. I then saw Nick's site and saw I "overpaid." Let's just say after a series of emails with Baja's COO, they corrected the issue to my satisfaction.
I also then emailed the COO about the quality, or lack thereof, of their instructions. He took a look and agreed with me. I also spoke to Paul in tech support. He too said he'd speak to the marketing department to improve the instructions and perhaps put up some videos on installs.
I'm about to try to route the wires on my rear tail lights. Wish me luck.
MDJAK
NY
And unfortunately it was a failure. I used the green wire with brown stripe, though there appears to be two. The wires are so thin that I don’t believe that crimped they supply can adequately bite into it. I did find the ground screw and as others have stated, real shame Baja Design does not provide the correct size loop and that you have to cut it open and hope you don’t break that ring. Now I need to try to understand how to do it via the trailer connector.
Speeddeacon
NC
Yes the ground lug is too small for the ground bolt on the truck, which is disappointing since it is a vehicle specific harness. I was successful in enlarging the lumen on 2 of the 3. I just used bare wire on the one that broke.
Ultimately you just have to get wire to wire in whatever reliable fashion works for you. Many of us use some sort of weatherproof connectors rather than the side tap.
Regarding the trailer connector, I posted pix on the backup light thread (#90) which should help you. It is ridiculously easy. The hard part is getting the lights mounted due to the proximity to the exhaust tips.
1badjk
Mississippi
How long is the warranty on your product? I have set of pro series cubes in a front light setup and they have water moisture inside and one has quit working. Had them for about a year, really hoped to get longer life out of these.
So I was about to take the lights off to send back for warranty after quick response from Paul @ BajaDesigns and then I realized a harness had come loose. So my lights are back working and I really appreciate the help from Paul.
Baja Designs
Baja Designs
Glad Paul was able to assist you and get the lights working again. Thanks for the update!
Baja Designs
Baja Designs
Check out these other great OEM kits we've released this March!
Ford, Chevy, and Toyota (COMING SOON)
2019 FORD RANGER FOG POCKET KITS
SKUS: PRO 447608 - SPORT 447607
Now Available | Order Today!
2019 FORD RANGER SQUADRON GRILLE KITS
SKUS: PRO 447610 - SPORT 447609
2019 CHEVY SILVERADO A-PILLAR MOUNTS
SKUS: PRO 447525 - SPORT 447524
2019 CHEVY SILVERADO 20" S8 GRILLE MOUNT
SKU: 447519
30" 4-RUNNER GRILLE KIT
Coming Soon
We have lighting kits for Toyota, Chevy, Ford, Dodge/Ram, GMC, Jeep, Nissan, and Subaru!
Baja Designs - Vehicle Specific Lighting
Baja Designs
www.bajadesigns.com
Baja Designs
Baja Designs
@t4arghhh (IG) aerial shot of dual amber LP9 Pros and amber Squadron Sports.
Perfect combination of near-field, mid-field and distance.
www.bajadesigns.com
1badjk
Mississippi
That’s an awesome pic!
Question on squadron pro lights. Is the lens the only difference between spot and driving? Basically can I swap the lens and it’s the same thing?
