Baja Designs: General Discussion Thread - GEN 2
Baja Designs
Baja Designs
Bryce Menzies #AWD laser equipped Trophy Truck is race ready for The Mint 400!
Who's going? March 6-10th, 2019 in Las Vegas, NV
www.bajadesigns.com
WRCRaptor
Great Lakes
Now that is a lot of light!!! So what is the set up on that truck? I see lots of bars and cubes in white and amber.
Baja Designs
Baja Designs
It's a little bit of everything ;)
I can't say exactly, if I come across a build list I'll certainly follow up and post.
Baja Designs
Baja Designs
*** Attention Honda CRF 450L Owners and other Motorcycle Enthusiasts ***
Looking to add performance on and off the street to your 450L? This is the kit for you, it utilizes your factory wiring and bar switch giving you a true plug and play setup with Hi/Lo functionality! The kit includes a mounting bracket that uses factory tabs, one Squadron Pro, and one S2 Sport.
Honda, CRF 450L, Headlight Kit, Squadron Pro/S2
Sku 490050 | $374.95 ------ $337.46 w/ Coupon Code: BDForums
Available Here
Includes:
Squadron Pro / S2 Sport Motorcycle Light
Adapter for CRF450L
S2 Sport Specifications:
Lumens: 1,130 Utilizing 2 LEDs
Wattage/Amps: 12W / .9A
Dimensions: 2.93" x 1.76" x 1.68"
Weight: 8 ounces
LED Life Expectancy: 49,930 Hours
Front Lens: Hard Coated Polycarbonate
Housing: Hard Anodized & Powder Coated Cast Aluminum
Bezel: Billet Machined Aluminum
Hardware & Bracket Material: Stainless Steel
Exceeds MIL-STD810G (Mil-Spec Testing)
Built-In Overvoltage Protection
IP69K (Waterproof up to 9ft & Pressure Washable)
IK10 Compliant (Mechanical Impact Testing)
Squadron Pro Specifications:
Lumens:
4,900 Utilizing 4 Cree LEDs
Wattage/Amps: 40W / 2.90A
Dimensions: 3.07" x 2.77" x 3.07"
Weight: 12 ounces
IP69K (Waterproof, Submersible to 9ft)
NV997tt
Available Here
Includes:
Adapter for CRF450L
Weight: 8 ounces
Lumens:
Weight: 12 ounces
Nice. What is your DR-Z400SM solution?
1badjk
Mississippi
How long is the warranty on your product? I have set of pro series cubes in a front light setup and they have water moisture inside and one has quit working. Had them for about a year, really hoped to get longer life out of these.
Baja Designs
Baja Designs
Sorry to hear about the moisture. The lights have a limited lifetime warranty against manufacturers defects. We are happy to get this fixed for you if you call us at 800-422-5292 or email detailed pics and info to [email protected]
We'll get it taken care of
Baja Designs
www.bajadesigns.com
Camarors64
I posted this in another thread but it should probably be here.
I've noticed there are different brackets from different vendors to hold the 3 light Baja design kit. Who's bracket is the best and why? Go!
Nick@Apollo-Optics
Baja Designs. It was literally built for their lights. Now, if you want to do something else where you have a bezel around the lights, then you may want to explore other options. Either way you want to go, we're happy to help get you setup.
