Baja Designs: General Discussion Thread - GEN 2
4x4TruckLEDs.com
I just switched over from an ADD stealthfigher front and honeybader rear to an ADD pro front and stock rear. I had rigid lights on the old ADD bumpers. I just put seven squadron pros on the front of my truck. I would like to put some lights on the back of the truck that turn on when I put the truck in reverse. That is what my rigid cubes used to do.
I also would like those same lights to function as utility lights. Something that puts out a lot of light in the back of the truck when hooking up a trailer or working outside at night. In addition to the lights turning on when I go in reverse, I would like them to turn on when I flip one of my aux switches.
What would you suggest? Thanks
We make a harness that does this. We offer it as part of our S1/S2 reverse kits OR as a stand alone harness. The harness lets you tie a pair of lights into your upfitter.
When purchased alone, it'll give you upfitter controller. When used in combination with an S1/S2 reverse kit, you can also have the lights come on automatically while in reverse
http://www.4x4truckleds.com/crystal...ness-for-2017-ford-raptor-s1-s2-reverse-kits/
What's nice about our harness, is that we don't back-feed your tail lights. So when your lights are connected to our upfitter harness AND your reverse lights (coming on automatically when in reverse), turning them on from your upfitter DOES NOT turn your factory reverse bulbs on.
4x4TruckLEDs.com
Which lights would you suggest based off of my needs above? What light pattern? Thanks
We have kits available for what you need. Available in the smaller S1 and standard S2 sizes. We run the S2 on our truck but a lot of customers are going with the new S1's as they are small/compact and put out a great amount of light.
Paired with our optional upfitter harness (mentioned above) you can control your lights from a switch OR when you go into reverse automatically
S1 Kit (Bolts under the bumper): http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-s1-reverse-light-kit/
S1 Kit (Flush Mount, cut into the bumper): http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-s1-flush-mount-reverse-light-kit/
S2 Kit (Bolts under the bumper): http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-s2-reverse-light-kit/
S2 Kit (Flush Mount, cut into the bumper): http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-s2-flush-mount-reverse-light-kit/
The S1 flush kit installs easier over the S2 flush kit, due to the size. I've seen folks do the S2 but you have little wiggle room.
kredd
Idaho
Recently went with some BD squadron pro fog kit. My review is below from the 4x4truckled site:
Amazing lights! Thanks to help by the 4x4 team via Fordraptorforum.com for the help during questioning -> purchase. Living in the desert of the southwest, I needed a nice blend of amber (for dust) + clear (for normal). I went with 3 Squadron Pros (1 amber driving combo/1 clear wide/1 clear spot), and am happy I splurged a bit more for the ‘Pro’ over the ‘Sport’. Light output is incredible. The stock OEM headlamps leave much on the table from overall output and these BD lights really help. The stainless steel mount is very well built but the instructions could be a bit more clearly defined. I did have some struggle with the install and it took me well over 3+ hours to complete. There isn’t much room to work with to tighten everything up based on the stock bumper. Small tip is to turn the wheel outward for the side you are working on, and replicate on other side following. I can’t speak to other lighting brands but BD seems to be the very top from my research. The added ability to quickly change out the faceplates is a huge bonus. Buy these lights you won’t regret it.
Baja Designs
Baja Designs
We appreciate the honest feedback, thank you!
Baja Designs
Baja Designs
New Product Announcement!
Ford Super Duty (20-On), 7 XL Linkable Kit
The latest vehicle-specific kit sporting our 7 light XL Linkable lighting system is Ford’s flagship hauler, the 2020 Super Duty. Pierce through the night with this thoughtfully placed and race-inspired setup. Powder coated 304 Stainless Steel brackets securely mount to the top of the bumper to place the light tight against the grill for a clean look. This kit will be offered in two configurations for Ford OEM upfitter switches, or our stand-alone harness.
This setup includes the following:
  • (1) 7 XL Linkable lightbar with black rock guards
  • (2) PS/DS Brackets stainless-steel & powder-coated
  • (2) Pre-load Support Base, stainless-steel & microtext
  • (1) 64-0115 Wiring Harness or (1) 64-0094 Upfitter Harness
  • All necessary hardware
Specs:
  • Setup: XL WC / XL DC / XL Spot / XL Spot / XL Spot / XL DC / XL WC
  • 22,050 lumens
  • 182W / 14A
Configurations:
Ford, Super Duty (20-On), 7 XL Linkable Kit | PN: 44-7732, MSRP: $1,689.95
Ford, Super Duty (20-On), 7 XL Linkable Kit w/Upfitter | PN: 44-7732-UP, MSRP: $1,669.95
Link: https://www.bajadesigns.com/products/Ford-Super-Duty-20-On-7-XL-Linkable-Kits.asp
Baja Designs
Baja Designs
Ford Super Duty (20-On), Fog Pocket Kits
On to the true work horse lights for this application, our 2020 Super Duty dual Squadron fog light kit. Our powder coated 304 Stainless Steel brackets are formed perfectly to the bumper to completely replace the fog light fascia and mount a Squadron SAE and your choice of squadron sport or pro series lights. Substituting the slim stock LED with a Squadron SAE + Sport/Pro combination provides exceptional lumen output for our Super Duty customers. Using either Ford upfitter switches or our stand-alone harness, our wiring solution will bypass the high beams to turn on all four lights at the flip of a switch. This wiring solution also preserves the OEM fog light functionality for the SAE Squadron pair using plug ‘n play adapters. Get ready for a tailor-made lighting setup that you can use in virtually any situation.
Each kit will come with the following items:
  • (2) Mounting bezels, stainless-steel powder-coated
  • (1) Pair of Squadron SAE
  • (1) Pair of Squadron Sport Driving/Combo or Squadron Pro Driving/Combo
  • (1) Wiring harness or (1) upfitter harness for the inner Squadron Sport or Pros
  • (2) plug and play adapters for the SAE Squadron
Configurations:
Ford, Super Duty (20-On), Dual FPK, SAE/Pro DC | PN: 44-7736, MSRP: $1119.95
Ford, Super Duty (20-On), Dual FPK, SAE/Pro DC w/Upfitter | PN: 44-7736-UP, MSRP: $1099.95
Ford, Super Duty (20-On), Dual FPK, Amber SAE/Pro DC | PN: 44-7737, MSRP: $1119.95
Ford, Super Duty (20-On), Dual FPK, Amber SAE/Pro DC w/Upfitter | PN: 44-7737-UP, MSRP: $1099.95
Ford, Super Duty (20-On), Dual FPK, SAE/Sport DC | PN: 44-7738, MSRP: $919.95
Ford, Super Duty (20-On), Dual FPK, SAE/Sport DC w/Upfitter | PN: 44-7738-UP, MSRP: $899.95
Ford, Super Duty (20-On), Dual FPK, Amber SAE/Sport DC | PN: 44-7739, MSRP: $919.95
Ford, Super Duty (20-On), Dual FPK, Amber SAE/Sport DC w/Upfitter | PN: 44-7739-UP, MSRP: $899.95
Link: www.bajadesigns.com/products/Ford-Super-Duty-20-On-Dual-FPKs.asp
Ford Super Duty (17-On), Reverse Kit
The last kit on our list for the (17-20) Super Duty will make your reverse lighting needs quick and painlessly solved. Utilizing our S2 Sport in a clear wide-cornering lens pattern, this kit places the light neatly underneath each side of the rear bumper well above the lowest point of the receiver hitch. There are two optional wiring solutions either using the Ford upfitter switches, or our stand-alone harness. If the thought of cutting into your brand-new Super Duty rear bumper keeps you up at night, rest assured our 304 stainless-steel brackets help to avoid any drilling/cutting and will endure the elements for years to come.
  • (2) Mounting brackets, stainless-steel
  • (2) S2 Sports W/C
  • (1) Harness or (1) Upfitter harness
  • (2) 10’ extension harness
Configurations:
Ford, Super Duty (17-On), Reverse Kit | PN: 44-7733, MSRP: $319.95
Ford, Super Duty (17-On), Reverse Kit w/Upfitter | PN: 44-7733-UP, MSRP: $299.95
Link: https://www.bajadesigns.com/products/Ford-Super-Duty-17-On-Reverse-Kits.asp
Slow6
AK
Specs:
  • 22,050 lumens
  • 182W / 14A
Configurations:
Are the XL80 the same bolt pattern as the XL Sport?
It’s like you knew I was looking at supers yesterday....
Edit:
Never mind, found my answer on your web page. Nice that there is no need drill holes. Any chance you are going to offer a similar mount for a 40inch OnX6 arc bar
Baja Designs
Baja Designs
Edit:
We know a lot guys on FRF have or want a Super Duty so we thought we would let you guys know what we've doing with them. :)
Correct, the difference between the XL Sport and XL80 would be the finish and the circuitry. But for the XL Linkable the housings are the same, gloss black powder coat with a hard coat anodize. It sounds like you're interested in an XL80 version of the XL Linkable? If so, shoot us a PM and I can see what we can do. We actually have a kit for the 40" Onx6 Arc on the Super Duty, check it out. https://www.bajadesigns.com/products/Ford-Super-Duty-30-40-Arc-Bar-Mount-Kit-17.asp
