iceman302
Full Throttle OG
It does look sweet. My PIAA's just showed up the other day. I'm probably going to mount them in the same spot. Now I just have to find time to do it.
Used these for backup lights, adjust at slight upward angle for city-its that forget there high beams are on, relay wired to reverse circuit and to switch #4 for that special touch.![]()
These are bright, but the brighter the better. which type did you use?
Electrical wiring is not my strong suit. What are the steps to wire them into both the reverse circuit and the #4 switch?
This is the diagram for the up fitter switches and revers lights,ford's wiring team have some sense of humor, put the up-fitter wires in the worst place they could find and color change from sw to glove to eng, they could have put a plug on each.
