OUTCAST
Without pulling my Head light out I can't tell you the wire color I tapped off but I used the + / - of the side markers. I tapped into them with Swenco positive lock screw tap so I wouldn't have to strip wires and removal, if I ever choose to completly remove it, would be nothing more than unscrewing and putting a rap of tape on it.
I took the +/- leads of the inverter and tapped directly into the marker circuit on the Drivers side away from the battery so I'd have more room to work.
Mounted the inverter behind the head light to the under side of the fender to keep it protected from water. Ran a lead inside the fender well to the vent.
Snipped the connectors off and directly spliced the EL lead and a long wire for the EL lead on other side of the truck.
Tucked it in the same place as justincrediblem but put the plastic wire wrap on the exposed wire to make it "factory"
Same concept as above but since my EL tape is neither Amber or Red and would not be confused as a marker light, I shouldn't need to turn them off for any Police officers.
Wanted to save my switches for something that draws more amps
