AutotecPro 14.4" Screen - Install and Tech Thread
XSTNKT
XSTNKT
Michigan
I have tried to set mine back to "Stereo" but it will not change. I clicked the "Reset All" button and it stays on surround.
I'm sure I missing something simple. Any help is appreciated.
My previous statement was referring to the setting in the Sync (stock) stereo settings. Not sure if I made that clear before. Sorry.
Darkwhip
Tri Cities TN
100% clear. When I go into the sync audio settings I cannot set "Stereo" it stays on "Suround". The button or tab in the top right conner for "Reset All" clicks and sets the fade setting back to center but still "Suround" is forced. Has anyone sen this before? TY!!
XSTNKT
XSTNKT
Michigan
Thats a new one. I can switch mine around.
JPinCC
I tried searching forum and didn’t see if this was covered.
Was able to install an emulator and run Bluetooth controller successfully. It was plugged in the video because the controller wasn’t charged
Do you have a write up on how you did this? Looks like fun. I just installed my screen yesterday and am getting it setup
WaveyJones
Lompoc, CA
Great thread, just got the truck and already thinking about this one for the wireless apple carplay feature.
Anyone experience issues with the bezel falling off while on rough terrain? Looks like it just snaps in and only uses two bolts on the top? Makes me wonder if its sturdy enough for the high speed washboard and whoops by the house
caleb
It uses the factory mounting. If your factory plate stays on, this should be no different. To answer your question I’ve had zero issues.
nikhsub1
Los Angeles
You can do wireless carplay now, I have the this 14.4" unit but still use this for wireless carplay via sync: https://www.amazon.com/dp/B0CYZQJ37J/?tag=fordraptorforum-20
Diverdown3
Indiana
Does the Autotec use any of the original hardware\electronics, like the HVAC controls? I'm guessing they have you transplant them (HVAC controls) from the OEM unit to the Autotec bezel.
