Audio solutions for your Raptor
The Car Stereo Company
here, on frf
you are best off using the oem tweeter location in the front. but yes the cxi is a coax speaker. the c3 is a convertable speaker, meaning it can be either a coax or a component depending on how you want it to be.
fshol
The Netherlands
I highly recommend the C3-570 speakers. I'm very pleased with mine.
Thanks, and did you mount the tweeters in the original tweeter location in the pillar? If so, easy fit, or does it take cutting/adapting? Does the pillar cover come off easily?
Nick@Apollo-Optics
Noah installed it for me at Raptoberfest. I'm sure he'll post shortly.
here, on frf
the passengers side pillar comes off with (2) 7mm bolts. the drivers side has a clip that holds the panel in place that needs to be carefully removed. the clip is $43 from ford. not hard to do if you have the right tool. i kept the oem silver grill in its location and mounted the tweeter on the backside with metal straps that screwed into the factory mounting holes. very simple once you get that airbag clip off
Nick@Apollo-Optics
I prefer the use of the OEM silver grille. The black grille that comes with the speakers has "JL Audio" on it. I'd like would-be thieves to not see my installed equipment advertised on the truck.
fshol
The Netherlands
What type of tool do you need, and where is the clip located?
Although probably answered, I have a question on the subwoofer. I have a crewcab with factory subwoofer, does the new one fit on the same mounting points. I need the space under the 2/3 seat, but i understood that your subwoofer 'fits under the 1/3 seat.
Last question: Do you ship international? If not, i will have it handled through one of our other US suppliers.
here, on frf
the clip os on the drivers side pillar up high close to the headliner. i use my handy snap on ******..... at least thats what i call it. i believe its called a cotter pin removal tool. you iust pull one side out first and then the other. i will try to find a picture of it somewhere. there is a video i posted with the removal of it. as far as international shipping, i dont have a problem with it, i always bill the actual shipping costs.
the fitment of the box is under the 1/3 side of the rear seat. i require 2 of your oem sub brackets though. so they will need to be shipped to me before i can build the box. do you have an amp and signal converter? or will you be using a sound processor instead?
fshol
The Netherlands
Where can I find this video/pictures?
I will also need amp and processor/convertor (please advise) and everything else that would be needed (including instructions) I thought that the second package that you selected could be the right solution, although we now speak of different speakers. Because of service over here, itmight be a good idea if i also take an amp from JL Audio, to keep it with one brand
here, on frf
pm me your phone number. i will call you when i have an available moment. we can discuss options for you.
