ARB COMPRESSOR INSTALL
Xexar
Ri
Darthyota,
any suggestions on location. I don’t think anywhere else under the body will be better. I was toying with the idea of bringing it up into the seem between the bed and cab but it would be very tight.
Darthyota
Alberta Canada
Being you have the compressor mounted under the truck i would run it up as high as is practical for servicing it but still higher then where you think you might ever get water. Behind the tail light would be good if its not too far. Or up somewhat between the box and the cab depending on where on the frame you've mounted the compressor
Xexar
Ri
Hi Nermol, Was the question for Wayne or me? I think Wayne fabricated his mount. I just bought some super strut from Lowes.
Old-Raptor-guy
USA
Surprised more are not using compressed CO2. I used ARB compressor a few times and switched to CO2. I can fill all 4 tires in under 3 minutes.
Getting the tank refilled is a little bit of a chore, but worth it to me.
ndk83
Dubai
Did you relocate the inverter? This looks ideal to me as you can still use the sapce under the seat. I have two car seats on the bench so the single seat is always up used to store things.
Another option im considering is custom fabricating a hinged bracket that will mount to the inverter mount that can be lifted alot with the seat.... but im liking what yo have @Darthyota have done
StraightSixM2C
NYC
The steel seat base frame around the inverter is quite heavy. Just made a “shelf” to bolt the compressor down on. Just an old snapon box shelf with a couple tabs welded to it. Strong enough for my 7 year old niece to stand on. One air chuck on each side of the truck and I can reach all 4 wheels with a 15’ hose.
My initial concern was heat. So far no issues.
