ARB COMPRESSOR INSTALL
Chris S
Alamo
One word of caution doing a frame mount, I spoke to the factory about this, it is water-resistant, not water-proof, also is=f it happens to be operating when there is water around it will suck it in and destroy the compressor, otherwise, I think the frame great spot, out of the way. I mounted a compressor in the bed and a tank on the frame rail.
jzweedyk
Moab/Winter Travel/Summer Travel
Disagree slightly with the single pump being light for 35" tires.
I didn't say it wouldn't do it, but the twin works better (it is two of the single pumps together, so almost twice as fast). Also, if you go up in altitude, the compressors even work harder and take longer. Again, if you can swallow the extra money, I think it is really worth it for the Raptor. Mine is mounted under the rear driver side seat (Scab).
K223
Florida
Question? Do these compressors require a tank or can they direct pressure fill from the actual unit? These look like great additions.
manny
San Jose Ca
no they do not require a tank
you can add one if you plan to use it for air horn or running air tools but for just airing up tires its best without tank
Sent from my SM-N975U1 using Tapatalk
