I just installed a lockpick in my '13 and was planning on streaming vid from my iphone 5, but the new connector on the iphone 5 does not support composite video and Apple does not plan on adding the support as they thenk everything should be over wifi... so has anyone tried to add an Apple TV using an HDMI to composite adapter and using the sync accesspoint setting to create a network so you can stream from devices like an iphone 5? I wanted to see if anyone had any luck with this before I buy a HDMI to composite adapter.
