Anyway to display outside temp in the gauge cluster?
jabroni619
So I like to check outside temperature periodically, especially if I'm driving up to the mountains or heading to the dessert, but the temp display in the nav screen goes away when Apple Car Play is up. Is there a setting that allows me to display it somewhere in the gauge cluster?
BurnOut
Stop using Car Play?
I dunno... my "home" screen has nav/traffic info on the left, radio/station info on the upper right, and phone information on the lower right... and time and temp along the top.
joegie
North San Diego
yeah, i just tap the ford sync icon and it displays the home screen.
J
jabroni619
What I'm trying to accomplish is being able to use Car Play AND view outside temp. I don't care if the temp is displayed in the gauge cluster or the nav screen, but I'd like to be able to view it with Car Play running.
joegie
North San Diego
on the car play press the ford sync icon, you can still use car play but it just brings you to the home screen that shows the map, audio, time, temp, etc.
J
jabroni619
Again, what I’m trying to accomplish is be able to use Car Play AND display my temp. I know I can toggle back and forth between sync and car play. I also know I can disable car play all together. Neither of these allow me to use car play and view temp simultanously.
Based on the replies I’m assuming there’s no setting to make this happen. So the next question is if there’s a forscan tweak to allow for this?
torrin
Nashville, TN
There is no documented FORscan parameter for that my last check.
realjones88
Does your home screen still show the actual map when using Car Play? Mine just shows a blank area that says "maps" with an icon that takes me back to Car Play... it doesn't show the actual navigation map.
