- Joined
- Dec 16, 2016
- Posts
- 17,942
- Reaction score
- 27,903
There warranty doesn’t seem to cover anything more than there products. Does NOT cover anything OEM like the motor if it grenades. Bottom line not tune it if your worried about warranty work.
View media item 14745
Their BASE warranty is what you posted. The optional powertrain warranty is on page 26 of the document you posted from.
https://www.roushperformance.com/media/pdf/LimitedWarranty.pdf
In relevant part:
WARRANTY COVERAGE
When a ROUSH Flash Pack/Power Pack Kit(s) purchased from an Authorized ROUSH Dealer is correctly and completely installed by a certified Ford automotive technician or automotive service technician certified by the Institute for Automotive Service Excellence (ASE) on an eligible, legally registered and licensed vehicle with an operational odometer, ROUSH will cover defects in materials and workmanship during the Warranty Period, as solely determined by us.
Below are those vehicle components covered and not covered under this warranty:
- ENGINE COMPONENTS
COVERED: Pistons, piston rings, piston pins, crankshaft and bearings, connecting rods and bearings, camshafts and bearings, timing chain and gears, intake/exhaust valves and seals, valve springs, oil pump, push rods, rocker arms, rocker arm shafts, lifters, and turbochargers (if applicable). If a failure of any of these parts damages either the engine block or cylinder heads, a remanufactured long block assembly will be provided up to the maximum coverage of $7,500.00.
NON-COVERED: Those engine components specifically not listed including, but not limited to, parts, filters, etc., that are required to be replaced as a part of the vehicle’s normal maintenance schedule are not covered under this warranty.
- TRANSMISSION COMPONENTS
COVERED: Torque converter, oil pump, governor, bands, drums, planetaries, shaft(s), sprag(s), bearings, shift rail(s), fork(s), and synchronizers.
NON-COVERED: All-wheel drive vehicles are excluded from transmission coverages under this Warranty. Failure of related parts external to the transmission that cause a transmission claim, including but not limited to, transmission coolers, levers, controls, etc., void coverage under this warranty.
- REAR AXLE COMPONENTS
COVERED: Rear axle, ring gear, drive pinion, pinion shaft, side gears, bearings, bearing cap, washers, slinger, axle shaft (F-150 models only), housing and housing cover.
NON-COVERED: Axle shafts (Mustang models only).
- TRANSFER CASE COMPONENTS
COVERED: All internally lubricated parts of the transfer case are covered under this warranty. NON-COVERED: The transfer case housing is not covered under this warranty.
Rev.7/30/2019 26
When you present us with a valid, properly documented warranty claim during the Warranty Period, ROUSH will replace the defective component(s) covered by this warranty or, at our option and sole discretion, refund the purchase price you paid for the particular ROUSH Flash Pack/Power Pack Kit(s) purchased. We reserve the right to improve or modify the ROUSH Flash Pack/Power Pack Kit(s) without assuming any obligation to update or replace any previously manufactured or sold ROUSH Flash Pack/Power Pack Kit(s).
OUR TOTAL LIABILITY PER COVERED VEHICLE UNDER THIS WARRANTY IS LIMITED TO $11,500.00 (AGGREGATE). EACH COVERED COMPONENT HAS ITS OWN AGGREGATE VALUE WHICH WHEN COMBINED EQUALS THE TOTAL LIABILITY PER VEHICLE. THE ENGINE IS COVERED FOR $7,500.00, $2,000.00 PER TRANSMISSION, $1,000.00 PER TRANSFER CASE, AND $1,000.00 PER REAR AXLE. THESE AMOUNTS CANNOT BE COMBINED TOGETHER TO AID IN THE REPAIR OF ANOTHER COVERED COMPONENT. IN THE RARE CASE WHEN THE REPAIR COST EXCEEDS THE ACTUAL CASH VALUE OF THE VEHICLE, WE WILL REFUND THE PURCHASE PRICE OF THE ROUSH FLASH PACK/POWER PACK KIT(S) ONCE THE COMPLETE KIT IS RETURNED PREPAID TO US.
A replacement ROUSH Flash Pack/Power Pack Kit(s) or component(s) that has been installed in accordance with our instructions, assumes the remaining warranty of the original replaced. If a ROUSH Flash Pack/Power Pack Kit(s) or any of its component(s) is exchanged, the replacement becomes your property and the returned Flash Pack/Power Pack Kit(s) or component(s) becomes our property.
WARRANTY DISCLAIMER/EXCLUSIONS/LIMITATIONS:
TO THE EXTENT PERMITTED BY LAW, THIS WARRANTY AND ITS REMEDIES ARE EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES, REMEDIES AND CONDITIONS, WHETHER **** OR WRITTEN, STATUTORY, EXPRESS OR IMPLIED. AS PERMITTED BY APPLICABLE LAW, ROUSH® SPECIFICALLY DISCLAIMS ALL EXPRESS, STATUTORY OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND WARRANTIES AGAINST HIDDEN OR LATENT DEFECTS. IF ROUSH® CANNOT LAWFULLY DISCLAIM ANY STATUTORY OR IMPLIED WARRANTIES THEN TO THE EXTENT PERMITTED BY LAW, ALL SUCH WARRANTIES SHALL BE LIMITED IN DURATION TO THE WARRANTY PERIOD AND THE WARRANTY COVERAGE DESCRIBED HEREIN. THIS WARRANTY COVERS ONLY DEFECTS IN OUR MATERIALS OR WORKMANSHIP, AND DOES NOT APPLY TO THE ORIGINAL EQUIPMENT MANUFACTURER (OEM) EXTERIOR ENGINE COMPONENTS, IGNITION, FUEL SYSTEM OR DAMAGE RELATED TO OR ARISING FROM:
THIS IS NOT A PERFORMANCE WARRANTY. IT DOES NOT COVER ANY VEHICLE IN WHICH THE ROUSH FLASH PACK/POWER PACK IS INSTALLED. IT IS A WARRANTY COVERING THOSE SPECIFIC COMPONENTS LISTED UNDER WARRANTY COVERAGE. EXCEPT AS PROVIDED IN THIS WARRANTY AND TO THE EXTENT PERMITTED BY LAW, ROUSH® IS NOT RESPONSIBLE FOR DIRECT, SPECIAL, INDIRECT, CONSEQUENTIAL, INCIDENTAL OR PUNITIVE DAMAGES RESULTING FROM ANY BREACH OF WARRANTY OR CONDITION, OR UNDER ANY OTHER LEGAL THEORY INCLUDING, WITHOUT LIMITATION, LOSS OF REVENUE, LOSS OF ACTUAL OR ANTICIPATED PROFITS (INCLUDING LOSS OF PROFITS ON CONTRACTS), LOSS OF THE USE OF MONEY; LOSS OF ANTICIPATED SAVINGS; LOSS OF BUSINESS; LOSS OF OPPORTUNITY; LOSS OF GOODWILL; LOSS OF REPUTATION; LOSS OF EARNINGS; PERSONAL DAMAGES; PERSONAL INJURY INCLUDING DEATH; PERSONAL EXPENSES (FOOD, ROOM, MEDICAL, DENTAL); RENTAL VEHICLE EXPENSES; TOWING; STORAGE OR ANY OTHER LOSS OR DAMAGE HOWSOEVER CAUSED INCLUDING THE REPLACEMENT OF THE VEHICLE ON OR IN WHICH THE ROUSH FLASH PACK(S)/POWER PACK(S) IS INSTALLED OR OTHER PROPERTY.
- g) USE OF FUEL WITH OCTANE RATING LESS THAN 91 (R+M)/2 (REQUIRES PREMIUM FUEL).
- h) IMPROPER INSTALLATION, ABNORMAL OPERATION, ABUSE, NEGLECT, LACK OF MAINTENANCE OR LACK OF FLUIDS, OR DAMAGE RESULTING FROM A COLLISION. OPERATION OF SUCH AN IMPAIRED VEHICLE WILL VOID THE WARRANTY. THE VEHICLE OWNER IS RESPONSIBLE FOR ENSURING NO FURTHER DAMAGE OCCURS ONCE DAMAGE HAS OCCURRED.
- i) COVERED COMPONENTS BEING TAMPERED WITH OR ALTERED FROM FACTORY SPECIFICATIONS (OEM OR ROUSH®).
- j) THE USE OF NON-ROUSH APPROVED ACCESSORIES, SUCH AS, HEADERS, AIR INDUCTION, FUEL ADDITIVES (IE. OCTANE BOOSTER), CAMSHAFTS, NITROUS OXIDE SYSTEMS, REAR END MODIFICATIONS, AND OTHER AFTERMARKET PRODUCTS.
- k) DAMAGE OR ABUSE RELATED TO TOWING, OVERLOADING, PCM RECALIBRATION, MISUSE, NEGLIGENCE, ROAD CONDITIONS, LIFT KITS, OVERSIZED TIRES, AND OTHER NON-ROUSH APPROVED MODIFICATIONS.
- l) PARTICIPATING IN OR PREPARATION OF THE VEHICLE FOR RACING (ON A TRACK OR OTHERWISE), FIRES, FLOOD, RIOTS, ACTS OF WAR OR TERRORISM, THEFT, VANDALISM, NATURAL DISASTERS, AND ACTS OF GOD ARE NOT COVERED.
