Anyone tow with their Gen 3 yet?
jimmyjamm
Bend, OR
I have a 2018 Gen2 that I tow a small toy hauler with, and fully loaded, etc. it is pushing the 8,000 lb threshold and does good. I use a WDH, with around 800 lbs. of tongue weight it had some rear sag until I upgraded to HD Deavers, then about perfectly level. Pic is with OE springs
TXSTEEL
I've been planning on getting a new truck the first of 2022 and a Raptor is at the top of my list, but I do tow a boat quite a bit and looking at a new one of those as well. My concern isn't so much the trailer weight as much it is the pay load of ~1300 lbs. You add 500 to 600 lbs of tongue weight, ~700 lbs for me, my wife and 2 boys and then a 100 lbs, for hitch and tonneau cover. I can't put anything else in the truck without being over the limit.
xlr8
Tejas
Yep that's the rub. You can add timbrens or eventually air bags or a heavier spring but you'll still legally be over the payload...if that matters to you.
ToadSmasher2K1
Home Is Where You Make It
Red Kingdom
Mine hasn't arrived yet but I'll be towing my 2 UTVs on an aluminum trailer. My gen2 did fine after adding the +3 HD leafs, hoping this truck will work fine out the box.
Here's my current setup, way overkill for what's i'm towing.
Very nice Prospector XL. I considered going that route instead of back to a Raptor.
