Backinblack
Lca's are an easy one man install. Just put it on a floor jack, lift into position and bolt up.
If there's no secondary mount on those, I'd recommend getting them and weld them on now.
Kind of crazy to pay a bunch of money for new lca's, just to deal with constant heim joint maintenance/replacement and not have any performance improvement.
I don't have any plans for a dual shock set up. I see what you mean by adding the secondary mount for the future.
Are you saying that Camburg LCA's wear faster and require more maintenance than the OEM arms?
Thanks for your input.
---------- Post added at 10:05 PM ---------- Previous post was at 09:55 PM ----------
The limit straps are to save you shocks when you go to gull droop. Normally the full momentum of the unsprung weight of the corner (Lca, uca, knuckle, brake, wheel, tire, etc) will be stopped by the droop bump region of the shock, however this can damage the shock internals as the bump stops wear, adding limit straps allows to to transfer the force required to stop the downward travel to the frame which is much stronger than the internal bump stop on the shock. With the weight of the camburgs you really want to running them to save your shocks.
Thanks for the excellent description. I'll pm you about the straps thanks.
