Analog "beeps" from time to time
NHDude4
Southwest, NH
As mentioned, it's related to incomplete boot of the electronics when you turn on accessory power or ignition. What isn't said is that I'm completely convinced this is related to battery voltage. I think when the battery is drained the truck must more completely shut down the computer which would normally be ready to boot immediately.
I think this because my dashcam runs full time off the OBDII, even when the vehicle is off, and in the last year I'll often see a loading bar on the main screen saying something like "system turned off to conserve battery". I think my dashcam has caused the factory battery to deep cycle more than intended and now it's prone to doing this a lot. I haven't gotten around to replacing the battery but I'll bet money it will fix the chime symptom.
Nibbl3s
I notice it happens with the zen module of I shut down the truck and get back in before the system fully shuts off
But my truck also did it with a bone stock system so who knows
Raptorial
US
Mine does this too, completely stock.
You’re a brave man taking it to the dealer for that.
HankTheTank
Mine does the same but I think it’s speaker related. If I adjust the audio to only play from the rear passenger speaker(s) I get no sound. Loose wire or something. I mostly listen to podcasts so haven’t cared enough to fix it.
Nibbl3s
Lol end up with more problems than when you started.
I think there was a forscan hack that someone found that would essentially turn off the error checking and force the sound through the speakers each time.
I haven’t cared enough to attempt this
