Amber Fog Lights - Which Ones Match OEM Amber Grill Light Color?
L
ljn21
Tega Cay, SC
We actually manufacture an amber lens for the KC Flex and the Baja Designs S1 that is nearly identical to the amber running lights on the Raptor.
As far mounting goes, we make a stainless steel bezel kit that completely fills the bumper opening and a universal optimized bracket designed to hold up to three full size cube lights.
Offroad Alliance is your premier source for all things LED lighting. Whatever you need, we can most certainly get you setup.
888-466-8991
Web: OFFROADALLIANCE.COM
Bezel
Optimized Bracket
Do S2s fit in the 3rd/outermost position or onmy S1s or the KC Flexlights?
4x4TruckLEDs.com
If you want to place the S2 in the outer most position of your fog light opening, you'll require a bracket system. Check out our CrystaLux Triple Fog Light Bracket here: https://www.4x4truckleds.com/vehicl...2017-2018-f-150-raptor/triple-fog-light-kits/
The brackets allow you to mount up to 3 pairs of Squadrons, or of course 2 pairs of Squadrons and 1 pair of S1 or S2 lights.
The bezel system mentioned previously in this thread only allows the 3rd position (outer most) to have an S1 or KC Flex light mounted. So if you want an S2, you need to go with a bracket system (ORA does offer a bracket as well).
Check out our video here that demonstrates the flexibility of our brackets, plus you get our Raptor Lifetime Guarantee:
OffroadAlliance.com
Boston, MA
For our bezel kit, the options for the outer most position is limited to the Baja Designs S1 or KC Hilites Flex. The S2 will not fit. If you're referring to our optimized bracket, the S1, S2 or KC Flex will work.
Tim V
IL
I have three of the Radiance Scenes on each side. I ran the amber halos on one of the aux switches (which are generally on) and the white lights on another. Pricey, but receive a ton of compliments. The whites will light up everything for 1/8 mile.
4x4TruckLEDs.com
Flatom
Florida
I was looking at those but was worried they would not light far enough ahead of the truck
Flatom
Florida
888-466-8991
Bezel
Optimized Bracket
What is the difference between the Baja s1 and the kc flex?
4x4TruckLEDs.com
KC Flex lights put out 975 raw lumen per light. Baja Designs S1 put out 2,375 raw lumen per light.
KC Flex retail for $226.99 (a pair) and Baja Designs S1 retail for $208.95 (a pair).
KC Flex use a DT style connector whereas the Baja Designs uses a Weatherpack connector.
The KC honestly don't throw much light at all, you'd be better off with S1 lights if you want a really small light in your bumper. Otherwise an S2 or Squadrons are more popular. In fact, now adays we find most folks are doing 3 pairs of Squadrons with our CrystaLux brackets over a single S1/S2 and 2 Squadrons.
OffroadAlliance.com
Boston, MA
Other than the aforementioned points between the KC Flex and the Baja Designs S1, it really comes down to what you're looking for. While not an SAE light, the KC Flex is not that bright and we've been told by numerous folks that they run it 24/7. The S1 on the other hand is quite a bit brighter.
KC Flex:
Baja Designs S1:
