Am I missing out on anything by doing my own oil changes and maintenance?
joey185
The problem with Ford doing the rotation is they don’t balance them, I always take mine to the tire shop because the 35 inch tire really should be balanced every rotation.
I did my own oil change at 5000 but I used the Motorcraft oil they suggested, I wasn’t sure what oil to use so I stuck with what they suggest.
sixshooter_45
Arnold
I think that if you've hit one of the front tires hard or have done hard off roading then it's a good idea to have them balanced or if you notice and abnormal steering after rotation otherwise balancing IMO is unnecessary.
wheelman55
Big Bend or MN
Get ceramic beads installed and you will never need to balance the tires. They will always run true. I've got them in Raptor, F350, plus on my double axle trailer. The beads work.
