Jarrett H
- Joined
- Dec 21, 2013
- Posts
- 177
- Reaction score
- 146
The preferred direction for strength, cost, and maintenance in the long run might be with a serviceable fixed spindle design. Unit bearings can't be serviced and when most designs fail, the truck isn't drivable. Although, the f450 unit bearing is SUPER popular because it is very strong, allows for a manual locking hub to increase drivetrain longevity, but also because the internal spindle is bolted together. So when things start to break, your wheel shouldn't pop off. You can also have a spare sitting in your truck if one happens to fail, you can replace it on the side of a trail or at Pismo.
Haynes, I know you are looking at different options so you'll probably like this. So with a fixed spindle style assembly, when the bearing starts wearing out, we can have a spare set of inexpensive bearings sitting at home that can be repacked and replaced at home or in a shop. This style would be bounds a leaps stronger than the f150 unit bearing and would allow for manual locking hubs.
The aftermarket spindle snouts are also forged and heat treated(mucho strong). Alright, so wait for it.....the icing on the cake is that there are a handful of companies out there that make fixed spindle conversions. They literally supply a forged snout that bolts on a factory upright in the stock location. That means you can remove the 4 bolts on the factory bearing, bolt this hub on, and maintain almost identical track width. No more IWE, increased strength, and manual locking hubs. Check it out.
