AIR HORN INSTALL
Gary E
Medford, Oregon
Wolo Model 845. Tone is 275hz. All chrome steel construction. Mounted the fabricated bracket to the existing square holes on top of each frame using nut clips. The relay is mounted near the top mounted radiator frame fuse box. The horn is activated by a separate momentary toggle switch independent of the original horn system.
2020FordRaptor
Nevada
I’ll offer a guess... 112-115 db with the stockers. I have the 2 compressor, 2 trumpet Marcos and get a solid 118db at some distance in front of the truck.
yeah, I think marco’s box says 150. They’re loud, but not that loud. You need something like 120-130 psi for that kind of sound out of trumpets that big. The electric compressors push about 20 psi.
Waggemay
INDIA
Wow, that Wolo Model 845 sounds like a beast! 275hz tone and chrome steel construction? That's top-notch! And mounting it to the existing frame holes with nut clips is a smart move. I love the idea of having a separate toggle switch for the horn - that's some serious customization. Have you ever considered pairing it with the Milwaukee train horn? I bet the combo would be absolutely epic!
