Bullishone
- Joined
- Aug 22, 2011
- Posts
- 1,382
- Reaction score
- 563
Nice . Well my wife drives it a ton so that's fine by me.Well, to be fair, your truck looks like a woman owns it.
Sent from my Nexus 6P using Tapatalk
Beautiful look! I have been debating how these wheels would look on a Raptor, this definitely convinced me. Thanks for posting!
Raptor W/ Fuel Beasts Photo by MagneticTiger | Photobucket
I just installed my new wheels yesterday. 20x9 +20 with 35x12.50 BFG's. I'm very happy with the stance pushing the wheels 1.3" to the outside where they are almost perfectly flush now. Also pleased with the DDT machined and black finish against the Magnetic. I'm in the midlands of SC, so I'm not able to blast through the desert in Baja mode regularly...thus the reason I went with 20's versus staying with 17's or 18's. Next step is installing my Eibach Pro-Lift springs when they show up...
Just FYI, stock offset is 34mm. Your offset is 20mm, so you only pushed the wheels out 14mm or 0.55". A 0mm or 1mm offset would have pushed the wheels out 1.3"...
Both of your calculations are slightly off...
Wheel Offset Calculator | 1010Tires.com Discount Online Tire and Wheel Store
I mistakenly calculated the stock wheels as +44 offset instead of +34. The Fuel wheels are 9" wide versus 8.5" stock, so the wheels are pushed out 20.4 mm or .8". So we were both wrong... haha! Thanks for the heads up though.
As I posted above though, the centerline of your wheel and tire was pushed out by .55"... So unless you got a wider tire than stock, then the outside edge of your tire was only pushed out by .55"
True but you also have to take into account the extra .5" width of the new wheel too. So it actually sits .8" farther out than stock due to the extra .25" width on that side of the wheel. .55+.25=.8
