Aftermarket Wheels
Wizo
Orlando
I don't think Method wheels suck - the offset is just a touch aggressive but it looks great.
Wizo
Orlando
I might trade the vex wheels for something else now.
I like the offset I have with the method wheels. If I went 20 inch wheels with 35 12.5 tires, what offset can I go with that won't rub? I don't plan on using a perch mod or adding collars.
Pacific Wheel
Reno, NV
May I get a quote on 17" bronze method nvs?
PM Sent
I'd probably go with +12 or higher depending on the brand of tire you plan on using.
Pacific Wheel
Reno, NV
LB on the new bronze finish Raceline Clutch's. Only 26lbs and hubcentric too. This particular truck is on 37's in case anybody is curious.
Wizo
Orlando
I would probably plan on the KO2's as I like the ride on the highway with them. The +12 will give me some level of poke out of the fender or look similar to the stock beadlocks?
PM Sent
Jayrod
FL
The 20" KO2's are 10 ply so they will ride a little firmer than the stock 17's.
May give the ridge grappler a try as well I am hearing they are on par with the comfort of the K02.
Pacific Wheel
Reno, NV
The BFG's are typically a little undersized so you'll be good. The +12 will poke you out an inch or so compared to OEM. You can go higher though if you don't want that kind of stance
