Aftermarket Wheels
crc
Heath TX
Nick@Apollo-Optics
What’s the setup on this ? Suspension , tire size , wheels , are they true Beadlocks ? I have a Gen 2 and ordered a Gen3 . I‘m keeping the Gen2 to use more oof-road . Thanks
In these photos:
17x9 Innov8 G400, -6 Offset
Bronze Anodize wheels, TechLite simulated beadlock rings, raw/machined clear-coated
37x12.50R17LT BFG KM3 Tires
Fox Factory Race Live Valve 3.0 shocks front/rear
Be glad to help get you setup if interested.
aaron1085
new england
Not all Ridge Grapplers are F rated but for 35x12.50R20 it's the only option. There is a 325/60R20 that's an E rated but it's slightly taller/wider but I'm not sure would make much of a difference. And some of the harshness can be lessened by running the correct pressure. They wont be as soft as a 17" c rated but the proper pressure will help.
Thank you for that gents. Currently the tires are set at 41/42 all around. Thoughts on this PSI?
