Aftermarket Wheels
NASSTY
ME
Ahhh - learning everyday. Are all Ridge Grapplers F rated? Other suggestion that would say ‘look as cool’ and maybe ‘ride smoother’ for down the road ..
The largest Ridge Grapplers for 20" wheels that isn't F or E rated is only 33" diameter.
Pacific Wheel
Reno, NV
Not all Ridge Grapplers are F rated but for 35x12.50R20 it's the only option. There is a 325/60R20 that's an E rated but it's slightly taller/wider but I'm not sure would make much of a difference. And some of the harshness can be lessened by running the correct pressure. They wont be as soft as a 17" c rated but the proper pressure will help.
YoshiTheRaptor
Vancouver Canada
JAWSRaptor
Miami, Florida
Love it! Have my mind set on these wheels as well, what tire size did you go with?
Also curious how much they stick out any rear or side pics? I know its not much, but I literally have inches on each side parking my raptor in the garage.
35" KO2s. I will attach some pictures so you can see the offset. IMO they stick out the perfect amount. Not too much and not too little. The white raptor in the picture has factory wheels/suspension, for comparison. IMG_1450.jpegIMG_1448.jpegIMG_1621.jpeg
JAWSRaptor
Miami, Florida
35 tires ? Does it Rub ? Looks sweet
yup 35. It rubs a very insignificant amount and only when i turn the wheel to maximum. Also, where it rubs is on the inner part of the plastic fender liner which is flexible in that area. im not worried about. Cant comment on offroading or jumping with this setup, would imagine you'd want to level it before jumping it but maybe some of the other guys can comment on that.
