Aftermarket Wheels
MnFlyer
MN
Got some Black Rhino Duggers through @Pacific Wheel. Great "deep" looking option in a +10 offset, and only weighs 24-25lbs per wheel. Ring on the outside is a rock slider that can be replaced if/when you scuff them up.
17x8.5", +10
View attachment 136313 View attachment 136314 View attachment 136315 View attachment 136316
Those diggers just look right in a Raptor. Nicely done.
So dumb question:
Would a 17x9 rim with +01 offset and a 35x12.5 tire cause any rubbing? I’m having trouble wrapping my head around the offset and how much that would change the geometry.
Pacific Wheel
Reno, NV
So dumb question:
Might have a touch of rubbing since the poke on the wheel is roughly 1.5" more than stock. Is the truck 17-18 or 19-20? The newer ones sit a tad higher in the front.
TheTeej
Denver, Colorado
Depends on the tire and the year of the raptor. 19-20 trucks you could probably get away with it, earlier years you may get mild rubbing at full lock without any sort of lift in front, be it springs or perch kit.
MnFlyer
MN
Thanks guys. It’s a ‘19
EricM
OHIO
I like those. Nice looking simple spoked design.
Are they hubcentric? Can you use the stock lug nuts?
