Aftermarket Wheels
Pacific Wheel
Reno, NV
Do you feel like the truck is level with the icon adjustment? I was going back and forth debating on if the 2.25 (vs. your 1.75 perch) was going to give me a nose high look vs level look.
The 1.75" does leave a slight rake. Icon kit is adjustable so you can run it at 1.75" or 2.25". The truck below is at 1.75". And for anyone interested in VenomRex we just got a deeper discount. Prices are very competitive.
Wizo
Orlando
Thanks for your response and those are sweet looking wheels. Do you think going up to the 2.25 will make it look off (*too high?) - that above looks perfect and I am over thinking this.
Pacific Wheel
Reno, NV
I think 2.25" is dead level. If you want a slight rake the 1.75" might be ideal. Can't go wrong with either IMO
waveslayer
CA
2.25 is dead level, love it. I'd go 2.25 over 1.75.
Remember to go big or go home
My wife thinks I only have 3 guns
Wizo
Orlando
Awesome guys - Thank you for your help. My local 4wd parts was saying that its honestly better to change out the springs vs. collars as it would definitely ride smoother. I am going to use the collars unless I feel that it is an issue. I did see one or two guys post about it creaking a lot down the road.
Pacific Wheel
Reno, NV
I only know of Geiser and Eibach for springs. The Geiser is about 2.5" which puts you a little nose high and the Eibachs had some pretty bad reviews about harshness. If you want to keep a smoother ride at 2.25" with collars I like the Icon setup. Instead of 2.25" of preload it's a 1.75" preload collar and a .5" top spacer. There are other companies out there if you want to split it right down the middle and go with a 2" collar. I believe baja kits and Camburg are offering an even 2" collar. If you want to go with the Icon collar I have a few in stock.
TxCOR
Florida
As others have said, I feel like the 1.75 has a very slight rake once it settled (you can kind of tell from the side shot) but I honestly like that look. When I first put them on, I got a little worried because the 1.75 almost looked nose high! But then everything worked in good!
As far as ride, I do feel more stiffness in the front but I feel like some people on this forum blow up the fact that anything over 1.5 makes it sooo much more stiff. Yes you feel a difference, to me it feels better, and on normal street driving, you barely even notice. I cant speak for the 2.25 but I love where its at with the 1.75, ride and look. And down the road if I ever wanted to go up a little more, throw the little spacer on top of the strut!
Wizo
Orlando
Thanks for the input. I kinda agree that maybe the 1.75 is the right number but will see here soon.
