Additional rust proofing?
Sungod661
How would you go about applying it? Juat spray it on when clean and dry?
Any precautions? Would 3-4 cans be enough? Also how long does it last? A year ? 2 years?
The Mav
start with 3-4 cans and see how far that gets you. I applied it after washing the truck, making sure to get all the areas I was going to apply it, make sure it's 100% dry then just spray it on.
most important part is making sure it's dry, otherwise you're just trapping moisture under there.
heres a before and after of when I did mine. had the bed off because i was doing my long travel rear setup at the time.
Before:
After:
that was done in july of 2014. It's just starting to wear off now and I'll probably go over it again this coming summer.
SonnyAK
Anchorage, AK
I sprayed my undercarriage down really well with Amsoil MPHD rust inhibitor as soon as I got it. It went on a bit yellow and waxy but hardened really well and lasted. When I sold the truck 3 years later, I had zero rust issues, but the truck wasn't daily driven either. t'll definitely use it again.
Wilson
South Dakota
I have all mine done
---------- Post added at 05:48 PM ---------- Previous post was at 05:46 PM ----------
It's more of an orange peel spray in bed liner.
Oceanbnd
Oceanbnd
Undiscovered Country - Alaska
There is one more "snag" with living here. There is nowhere to wash your car. There is one car wash on the island. It has a spray nozzle on the side but unfortunately the owners turn it off during the winter. One would have to hand wash their car with warm water and buckets to keep the car free of gunk. And there's soooo much gunk
Ditchplains1
Trescott, ME
OceanBnd,
Search the forum and/or Google for "Ziebart". I've had all of my cars and trucks treated over the past 30+ years all without rust ever raising it's head....
As for aluminum 'just oxidizing'...iron/steel oxidation is called rust; aluminum oxidation is called corrosion....
Just as bad! We have a lot of Land Rovers out here, surrounded by the Atlantic. The frames rust, and the bodies corrode....
ZIEBART!
http://ziebart.com/
Eddie
Oceanbnd
Oceanbnd
OceanBnd,
ZIEBART!
Ziebart | Home
Eddie
As with most things in this state, there are no Ziebart dealers here. It's crazy how little is available here. I'm going to take my truck to the only detailer on this rock and see what product they use.
