Yukon Joe
I was wondering if you got that from work....Yes it was spendy, but I had the opportunity to buy the hydraulic wrench for halve price after it was used only once, by me, and I couldn't resist.
I think this is a good set up.I would have paired the multiplier with the digital torque adapter as mentioned and linked above. I was apprehensive about a $70 multiplier so I ended up getting the torque adapter, 3/4", 38" long breaker bar, and a 3/4 to 1/2 reducer.
I figure with a roughly 3' long breaker, I would only have to exert about 108 lbs of force for the steering rack and 134 lbs for the lower control arms which is reasonable. I Only spent about $150 for a setup that could potentially go up to 750ft-lbs.
I'm curious how the digital torque adaptor works. It's a multiplier, but what mechanics are on the inside to advice what you want?
Perhaps it's a 3:1 multiplier and the digital part is only doing the math and read out?
Let's hear some feedback once you've put it to use.
@Yukon Joe
www.runraptorrun.com
