Achieving 406 ft/lbs on lower shock nut
Towerhog
Southeast CT
And when you torque that lower shock bolt to specs, you should torque the nut and not the bolt itself. The nut has a captured washer that allows the nut to turn. The bolt does not have that washer should stay stationary during the process.
moog5050
Just use the same wrench my dealer did when it rotated the tires causing the disc to warp at 19k miles. Last time I had them do that, or anything, out of convenience.
McGrath4u
Bumping up this thread to see opinions on two setups I'm thinking about to do steering rack bolts and eventually the LCA bolts.
Option 1
-3/4" digital torque adapter
https://www.amazon.com/dp/B009GLITFW/?tag=fordraptorforum-20
-3/4" breaker (38")
https://www.amazon.com/dp/B00OXUPHTW/?tag=fordraptorforum-20
Option 2
-torque multiplier
https://www.amazon.com/dp/B01CZ23MNC/?tag=fordraptorforum-20
I like the versatility of the multiplier, though cheap, with tools already in possession.
Thoughts?
