LuvofGTI22
- Joined
- Aug 30, 2017
- Posts
- 5
- Reaction score
- 1
Oh speaking of weak points, you should probably do some research on the Lower Control Arm pivot bolts if you haven't already, Ford uses a slotted setup there that can be problematic under hard (i.e. Raptor) use. There's solutions ranging from solid pin and/or welded reinforcement (will require adjustable Upper Control Arms) to alignment cams like this (which I'm planning on doing along with the shock rebuild, SDHQ among others have them):
http://www.fordraptorforum.com/f9/wheel-alignment-cam-bolts-20583/
I'll check these out. Looks like an easy DIY. Thank you.
