t_j
Can you explain how this would be the case and how the crankcase breather would factor in ? I am not saying its not the case, I am not envisioning how that would be the case when taking into account the breather so I am seeking information . respectfully . Tim
I want to also add that it seems, in my mind if this were the case of too much crankcase pressure oil would be being forced out every possible orifice, again just trying to envision this not attacking you, I am not an engineer, just some what mechanically inclined and I like to understand the physics and mechanics of things. Tim
For extreme overfill there will be oil in the bottom of the cylinder and the piston will be forced down though it adding much higher pressure to the rings causing blow by and eventually ring failure.
For minor overfill the oil will foam due to excess part motion through it, this foam does not flow (it sticks to surfaces) and will among other things stick to the cylinder wall, again increasing pressure on the rings, blow by and eventual failure. The oil foam will also cause air bubbles in the oil galleys causing parts not to get the correct level of lubrication leading to overheating and failure.
As for oil spraying out every way it can, this is unlikely as the approx volume of the case stays the same as some pistons will be moving up as others are moving down creating spaces for the displaced oil to flow into.
It should be noted that it would be difficult to crank and engine that was so full the pistons where hitting the oil surface, if it would even start, at least in small displacement blocks.
