Ruger
The two fluids didn't mix because they're not compatible or because the engine failed so precipitously that they didn't have a chance to mix. There's a mechanical failure somewhere in this, especially given the description of the failure provided by Paul Stone. If the second fluid is coolant, it's bound to be a head gasket failure.
The thing I don't understand is the initial 6 quarts of what looked like fresh clean oil. After 4,000 miles? That's got me really puzzled if it really is oil. If it's coolant, then there's no real mystery because the coolant would separate while the truck's been sitting, would be the bottom layer in the crankcase, and would be the first fluid to drain. But coolant doesn't look like oil, so I'm really scratching my head over this.
