BigBlackRaptor
I have been trying to diagnose an extremely loud grinding and banging noise for the past few weeks and I am at a loss. I am almost certain this is not an IWE issue as I have had both IWE's go out before and this is a VIOLENT noise and can be felt on my feet through the floorboard.
I first noticed the noise after having a fairly well known shop in LA do some work done on the truck. What I had done there:
- Driver side Spindle
- Steering tie rod ends
- 37's and pinch welds
- Front Brake pads
- Upgraded UCA bolts
The day after I got the truck back this intermittent noise started happening on the freeway. Went away for about 20 minutes, came back again.
I went back to the shop that worked on the truck and they recommended that I change the transmission mount because it was essentially torn in half. A different shop performed that work and I thought I was home free. About 3 weeks later (yesterday) the noise came back.
When I got home, I got under the truck and decided to play around with the idea that it might be the 4wd system. With the truck and engine turned on in 2wd, I put the transmission in nuetral and tried to rotate the Driveshaft going from the transfer case to the front diff and I was able to rotate it. I was also able to rotate the driver side CV shaft. I was not able to rotate the passenger side CV shaft. It very clearly felt like it was engaged and locked in.
Thismade me want to pull the vacuum lines from the hubs. both hubs were getting vacuum. Gave up for the night.
Today, I had already scheduled with yet another shop to do the trans fluid, gasket, and Lead frame, Had that done. Driving home from the shop the noise started on the freeway.
The noise happened 2 times yesterday and 2 times today. Each time i let it go for anywhere between 3 and 10 seconds and I shifted from 2hi into 4hi and as soon as I did, the noise would go away. I got back to 2hi and wait a few minutes of driving around and it would eventually come back.
What the actual hell is going on here?????
PLZ HALP
- Front Brake pads
PLZ HALP
